EPLAN 2.1 - maximum logic pages reached
Hello hello,
Im using Eplan Electric P8 2.1 SP1. In my project I have 10 multifilar pages and when I try to make the 11th it says that it has reached the maximum number of logic pages...
Anyone had this problem in the past?
Re: EPLAN 2.1 - maximum logic pages reached
Forget about v2.1, there was never a proper crack for that version (licence on this forum is some sort of demo which allows only up to 10 pages). Use ePlan v2.2, working crack is available
Thanks for your info. But could you please give me the working 2.2 version link, I searched out the internet, none of them seems well.
Thank you a lot!
Thank you a lot!
This is topic for ePlan v2.2 : viewtopic.php?f=7&t=18563
And inside topic viewtopic.php?f=7&t=18462 is crack which is working for me (Win32).
Thank you a lot. It is said that edz files cannot be imported in crack version. That only works in data portal, which only genuine users can access.
Is that true?
Is that true?
I didn't know what edz files are until you mentioned them. Seems interesting, and according to this topic (italian forum) http://automazione.plcforum.it/index.ph ... -file-edz/ it seems that edz is packed file (7z or zip) from which macro's and xml parts file can be extracted.
If you have some interesting edz file maybe you could share it (or link where you got it) with rest of forum members
After I searched the internet, I found that edz import function is built in eplan 2.2 . Have a nice day~
But this function is available in data portal which connects the EPLAN server, so it is only for genius users ........
Here is a work around for import .edz files to EPLAN 2.2.
Rename the edz file to zip.
Use winrar to unzip it.
In EPLAN,
+ open part management dialog: Utilities -> Parts -> Management
+ open import records diaglog: Extras -> Import
+ Select file type: XML
+ Select file name: look for xml file in subfolder "items\partxml\" in extracted folder
+ Press OK to import.
Hope this help
Checked with EPLAN 2.2 and edz file downloaded from Siemens support site.
In EPLAN,
Hope this help
Its doesn't work. WHY it was possible with EDZ without any problems in the 2.1 Version and absolutley not, now ???
