EPLAN P8 2.2 crack
Тools, Elcad, Eplan, ...
PDLFFALF
EPLAN P8 2.2 crack
Post by PDLFFALF » Mon Oct 01, 2012 12:01 pm
Does anyone have EPLAN P8 2.2? please '' share '' thank you
crack:
EPLAN P8 2.2 CRACK-TEMP1.rar
http://eplan-eb2.ys168.com/
http://bbs.e10000.cn/a/a.asp?B=203&ID=1220778
van8x10
Re: Request: EPLAN P8 2.2
Post by van8x10 » Sun Oct 21, 2012 6:42 am
Pls see topic viewtopic.php?f=7&t=18563 and give solution!
van8x10
Re: EPLAN P8 2.2 crack
Post by van8x10 » Fri Oct 26, 2012 11:04 am
I can't Crack the v2.2 (shared by sadefa) on my PC with Win7x64, even if with Test Mode. Please help!
jihad_abuhoran
Post by jihad_abuhoran » Sat Oct 27, 2012 7:44 am
van8x10 wrote:I can't Crack the v2.2 (shared by sadefa) on my PC with Win7x64, even if with Test Mode. Please help!
Same for me, it is not working
Josivan
Post by Josivan » Thu Jan 31, 2013 1:46 am
Can not run my EPLAN with the methods presented here, have some other way to generate the Dongle for Eplan 2.2
Windows 7 - 32bit (h) (h) (oo) (oo)
Josivan
Post by Josivan » Thu Jan 31, 2013 4:42 am
Hello all.
I managed to run Eplan 2.2 on Windows 8 32bits, however using the method of crack (2.2 CRACK EPLAN 10/23/2012) did not work, then opening the file setup.bat, I realized that it only copied the files to specified folders .
I describe here the steps I have done and it worked on Windows 7 32 bit and Windows 8 32 bit:
1 - Install Eplan Electric P8 2.2, follow the step usually gotten the istalação NOT RUN.
2 - Copy the file hardlock.sys to the directory C: \ Windows \ System32 \ Drivers
3 - Copy the file MYLOCK.FST to the directory C: \ Windows \ System32 \ Drivers
4 - Copy the SN-U10066.EGF to the directory C: \ Users \ Public \ EPLAN \ Common
5 - Restart the PC and start the EPLAN Electric P8 is ready to use.
I hope everyone Funcine con.
I'm leaving a sample image.
Show
donggq
Post by donggq » Sat Apr 26, 2014 3:13 pm
good job! thank you!
DUVAN8
Post by DUVAN8 » Fri May 23, 2014 11:28 am
Hi all,
"EPLAN can only be run on your system with reduced performance because of a hardware confict"
error:4521
Please contact your local retailler to fix this problem.
This is a fake message, because you use a software emulated hardware key
Click on the close button, and use it...
But it has a 1 month license only. If you set the system time of the computer forward with 2 months, it will stop working... :(
