Aucotec Elcad Aucoplan v7.11
Тools, Elcad, Eplan, ...
john_smith
Re: Aucotec Elcad Aucoplan v7.8.0
Post by john_smith » Sun Dec 14, 2014 5:07 pm
version 7.10 on Aucotec site :
https://www.aucotec.com/modules.php?op= ... ask4mail=0
@bsod, can you do some magic ? ;)
thenewer
Re: Aucotec Elcad Aucoplan v7.9.0 SP2
Post by thenewer » Wed Jan 28, 2015 12:18 pm
Can anybody help me with elcad 7.90 SP2
Thank you very much
pepe1232
Post by pepe1232 » Sat Mar 14, 2015 7:16 am
Anybody help me with elcad 7.9.0 sp2 in spanish. I need activation Thank you
bichochu
Post by bichochu » Sun Apr 12, 2015 3:57 pm
I installed the Elcad v7.9 sp1 Italian version and use the crack for this version , copy the file alwin.exe and then install the Spanish version sp2 and copy this file and it works.
No if it worked mostly because I have not tested thoroughly but apparently yes. ; )
Download Link
Password : aucotec
https://mega.co.nz/#!H1pSkJSJ!ax7RdLaXm ... 6pyEvWt9aE
keymak
Post by keymak » Sun Oct 11, 2015 4:42 pm
Hello
I am searching the medicine for Elcad 7.10 with SP3 for German
Thanks for all :haha:
keymak
xblu
Post by xblu » Sun Jan 03, 2016 11:57 am
(oo)
xblu
Post by xblu » Sun Feb 28, 2016 5:00 pm
7.11 ???
john_smith
Post by john_smith » Wed Mar 09, 2016 7:03 pm
hi,
v11 can be downloaded from aucotec site ...
https://service.aucotec.com/modules.php ... ask4mail=0
but it needs some magic :)
bsod
Re: Aucotec Elcad Aucoplan v7.11
Post by bsod » Thu Mar 31, 2016 4:05 pm
for Aucotec Elcad 7.11.0 - NOT TESTED !!!
http://www.xup.in/dl,14889229/aes7110.rar/
Pass: Aucotec
bsod
duckman
Post by duckman » Fri Apr 01, 2016 7:17 am
Thanks bosd for the clean crack, l also haven't tested it.
Result of crack check
VirusTotal
SHA256: 4cc72109e5e3f8fac787ddfc2cd3b3da85541454dd5f826ded37b81e12d2c13f
File name: alwin.exe
Detection ratio: 0 / 56
Analysis date: 2016-04-01 07:10:10 UTC ( 1 minute ago )
Regards
john_smith
Post by john_smith » Sat Apr 02, 2016 2:21 pm
thanks bsod,
confirm working ..
dvnhan
Post by dvnhan » Wed Apr 27, 2016 3:03 am
Could you re-upload medicine of V7.11?
Tks!
Carlos
Post by Carlos » Wed Apr 27, 2016 7:31 pm
do not forget to uncheck the box below
https://www.datafilehost.com/d/b981d68c
771
cakal477
Post by cakal477 » Thu Apr 28, 2016 7:20 am
alafandy wrote:Aucotec Elcad Aucoplan v7.11
Author: AUCOTEC AG
Version: 7.11
file : ISO
Download Direct Link ELCAD 7.11 here :
cakal477
Post by cakal477 » Thu Apr 28, 2016 7:28 am
crack file for elcad 7.11 please
Carlos
Post by Carlos » Thu Apr 28, 2016 8:03 pm
https://www.datafilehost.com/d/133e698b
711
edit: is down
cakal477
Post by cakal477 » Mon May 02, 2016 1:40 pm
please 7.11 crack file
Carlos
Post by Carlos » Mon May 02, 2016 4:57 pm
selftester
dvnhan
Post by dvnhan » Mon May 02, 2016 5:45 pm
Thanks you very much, Carlos!
Fuso
Post by Fuso » Thu May 12, 2016 9:01 pm
Hi all, i'm new!
I need medicine for elcad 7.11 and please tell me how to apply this medicine (wow)
Hatshepsut82
Post by Hatshepsut82 » Wed Jun 29, 2016 11:31 pm
Hi Everyone, I´m really need this software but i checked already all the links here and I can not find any version of Elcad with the respective crack or medicine, all links are already blocked :´( I just want this software Elcad in any version with the respective crack. If someone can please help me! Pleassseeee. Thnks.
Carmelinfc
Post by Carmelinfc » Sat Aug 06, 2016 11:42 pm
I just downloaded the iso version 7.11. from: https://goo.gl/qJT64R
Is there any medicine to activate the program?
Carmelinfc
Post by Carmelinfc » Thu Aug 18, 2016 11:38 am
I just downloaded the files to medicate the program. :smile:
I just try and do not work. :( :( :(
Get the following message:
"Program files differ from the original ones.
The program might créate erroneous Project data."
After then close the program.
Know any other solution to disable the "demo" function and to work with all features.
john_smith
Post by john_smith » Sun Aug 21, 2016 9:43 am
try to uninstall, then clear registry (anything involving elcad) and install again
don't start the program before applying patch
Carmelinfc wrote:I just downloaded the files to medicate the program. :smile:
Carmelinfc
Post by Carmelinfc » Mon Aug 22, 2016 3:58 pm
Thank you very much for your help John_smith. (tyou) (tyou)
I just followed his instructions and now it seems to work. (clap) (clap) (clap)
Then leave the steps taken to get it to work properly for those who may need:
1 Download the program from: https://goo.gl/qJT64R
2nd Download medicine from: 7110.rar - 3.5 MB
3rd Delete the pc making reference to AUCOTEC and Elcad. Both files and registry entries. For this I used the REVOUNISTALLER program.
4th ELCAD program installed version 7.11
5th run the program and leaves a window of selection of type of rules to use. Select appropriate to needs, normally IEC-international.
6th Give OK
7th Copy the file of medicine in the working directory.
and ready. (suc) (suc)
kip_88
Post by kip_88 » Mon Aug 22, 2016 7:19 pm
Carmelinfc wrote:Thank you very much for your help John_smith. (tyou) (tyou)
6th Give OK
Where is the link for second, 7110.rar?
Carmelinfc
Post by Carmelinfc » Mon Aug 22, 2016 8:58 pm
keymak
Re: Aucotec Elcad Aucoplan v7.12
Post by keymak » Tue Apr 11, 2017 12:43 pm
Hello
Is there any medicine to activate the 7.12 version ? (pgood)
keymak
kashavar
Post by kashavar » Sat Apr 29, 2017 12:42 pm
The requested file (ID# bfea6f4f) no longer exists on DATAFILEHOST.COM.
Can anybody help
Respect
kashavar
mogz
Post by mogz » Wed Apr 04, 2018 4:09 pm
is there any help for Elcad v 7.13 / Elcad 2018 ?
KalBur
Post by KalBur » Thu Aug 16, 2018 1:39 pm
Please some one to help me wit medicine: 7110.rar - 3.5 MB
M1S5
Post by M1S5 » Sun Nov 11, 2018 2:36 pm
is there any "help" for the latest version of Elcad - Elcad 2019
jgonzcas
Post by jgonzcas » Thu Nov 15, 2018 3:40 pm
mike1976
Post by mike1976 » Tue May 14, 2019 7:01 pm
No medicine ?? (oo)
mos388
Post by mos388 » Tue Oct 01, 2019 4:25 pm
I'm also interested in this matter...
Anyone?
