[request] PDF TO DWG
Hello. Can anybody give a link to converter dwg to pdf. I use AIDE PDF to DWG conwerter but it's only 20 days. Please help me. I need to convert 500 pages
Re: [request] PDF TO DWG
What version do you use? I found patch for AideCAD PDF to DXF Converter 9.6:
http://slil.ru/28765092
I did not test it, so please try and tell me if it works.
thanks a lot, i try to same patch but it's not work or it was fake. Thaks a lot !!!
Acrobat 9.0 Pro can batch convert DWG to PDF. The coverting speed is pretty fast as well.
Jo
Jo
Autocad 2010 can convert dwg to pdf without any programs, i need to convert pdf to dwg and AideCAD makes it greate.
I have used these programs in trial mode
http://www.bluelabelsoft.de/ + "PDF To DXF JPG TIFF Converter"
and
http://www.aidecad.com/ -
One of these programs works well.
Another program is lying - the result unsatisfactory.
But the name of a good program can not remember - possible "PDF To DXF JPG TIFF Converter".
Try it yourself.
and
Try it yourself.
Russian wrote:Я использовал эти программы в trial режиме.
Одна из этих программ работает хорошо.
Другая программа врёт - результат неудовлетворительный.
А вот названия хорошей программы не помню - с коллегами склоняемся, что это был "PDF To DXF JPG TIFF Converter".
Пробуйте сами.
Hello is possible upload patch for AideCAD PDF to DXF Converter 9.6.Please help me
