It is currently Wed Jan 16, 2019 5:33 pm
PostPosted: Tue Sep 03, 2013 7:44 pm
Hello everybody! Please, help me with the problem. I need an ISO GX Works 2 1.40s.
Here I can't find any working hyperlinks.
I crucially need a working hyperlink.
If you have any of them, please, send me asap.
PostPosted: Tue Sep 03, 2013 8:52 pm
http://rutracker.org/forum/viewtopic.php?t=4518630
Setting Trial for 60 days. Then extend the change in the registry date of installation:
After 59 days (or sooner), type in the command line regedit.exe, look for HKEY_LOCAL_MACHINE \ SOFTWARE \ MITSUBISHI \ SWnDN-[Nazvanie_programmy] \ CurrentVersion, and changing the date in the current InstallDate, we continue to make money:)
Установка триалом на 60 дней.
Потом в реестре продлеваем изменением даты установки:
Через 59 дней (или раньше), набираем в командной строке regedit.exe, ищем HKEY_LOCAL_MACHINE\SOFTWARE\MITSUBISHI\SWnDN-[Название_программы]\CurrentVersion и изменив в InstallDate дату на текущую, продолжаем зарабатывать деньги : )
PostPosted: Tue Sep 03, 2013 9:05 pm
Oldman thanks a lot for your help! don't you have something like license key or product key for this version?
I want to have one that not to do trial reset every 60 days.
thanks a lot!
PostPosted: Wed Apr 13, 2016 6:19 am
links here, thanks (dlink)
http://esouthnorth.blogspot.com/search/label/Software%20Mitsubishi#
PostPosted: Wed Nov 08, 2017 7:42 am
Update GX Work3 E038Q
http://www.filedwon.info/pwhp0c90wtg8/s ... q.zip.html
