[?]: Data in Taglogging Manager
hoangnguyen1986
Post by hoangnguyen1986 » Wed Dec 03, 2008 3:27 pm
I made a project in Wincc to archive data from a Tag of PLC S7-300 to WinCC6.0.
I get data from Tag online and save it to Taglogging and the result in folder "TagLoggingManager" (WinCC Project) I have some data base file with the external ".ldf" and ".mdf".
I don't know how to open it, and could we convert these file to Excel
Please help me?
eco__7
Post by eco__7 » Wed Dec 03, 2008 7:16 pm
hello,
one way you could get the data from the database is using the connectivity pack(here you use a dts to export data..for example).
If you want you maybe should use de DataMonitor, it is usefull too and reports via web.
other way is using odbc.
other way is openning the table of SQL, here is a table that can be access and shows every tag of the tagloggin (tomorrow ill give you the name of the table).
"i used Connectivity pack"
hoangnguyen1986
Post by hoangnguyen1986 » Thu Dec 04, 2008 12:28 am
thanks for your support
Please tell me something more how can we export or acess the database. Can you show me where I can find "conectivity Pack" and how to use it
marcs7
Post by marcs7 » Thu Dec 04, 2008 8:04 am
hoangnguyen1986 wrote:thanks for your support
http://plc.net.ru/search.php
http://support.automation.siemens.com
