[?]: OP17, upload COM problem, have only USB-serial adapter.
jamrobe
Post by jamrobe » Wed May 07, 2008 7:56 am
Hi everybody.
Need to upload a OP17 siemens panel.
Tried with ProSave but it would not accept Com5, only Com1 or Com2.
ProTool accepts other coms, but when I want to back-up it starts ProSave etcetc.
I will try to get a Serial Port Mapper to map Com5 over Com1, however, any other suggestions?
Jam
Post by sania » Wed May 07, 2008 9:35 am
go to device manager & find who use com-port 1 or 2
change number from 1 to any non used
go to your com-port & change
saugarm
Post by saugarm » Wed May 07, 2008 2:28 pm
you can try this for to find your comport
http://plcforum.uz.ua//SetCOM.exe
jamrobe
Problem solved
Post by jamrobe » Thu May 08, 2008 9:52 am
Thanks for help.
sania : good advice :), the only problem on the beginning I couldn't find port settings for my USB adapter, but after reinstalling the driver from original cd all went ok.
saugarm: thanks for utility, good to have it.
Regards
Jam
