[?] how to upload and download user program to OP3 panel
sadoudkarim
Post by sadoudkarim » Sat Sep 29, 2007 3:41 pm
request informations about how to upload and download user program to OP3 panel.
i have protool v6.0sp2 .
this panel has an old program inside,
and it's impossible to access.
thanks for your answers
Umencho
Post by Umencho » Sun Sep 30, 2007 7:12 am
for download to OP panel you use protool (must connect the pc with panel with right cabel, and make some settings in protool download area).
but for upload from OP panel you can only use some version of PROSAVE. And You can only make upload the program and after that download to same OP panel type, without make any changes in the program. :x :x :x
best regards
umencho
soloplc
help OP3
Post by soloplc » Wed Jan 20, 2010 11:40 pm
hi all
Siemens information indicates that it can not support an OP3 and C7-621 using the software PROSAVE. someone knows the world as you can get an endorsement of such devices in the PROSAVE there two types of panel so apparently there is no way back.
certainly the Decorder PROSAVE works very well.
thanks for your help
Umencho
Re: [?] how to upload and download user program to OP3 panel
Post by Umencho » Sun Jan 24, 2010 8:01 am
Seems my previous answer should be edit. :oops: So, if we have in mind OP3 (or C7-621) there is no way to upload program from it. There is only transfer function available using Protool software. By the way, perhaps is not so useful to upload program from there. This is only few tags and is possible to understand and build new program using Step7 program...
Best regards,
Umencho
coolvasek
Post by coolvasek » Fri Mar 22, 2013 10:08 pm
Здравствуйте всем!
Я хочу закачать проект в OP3 через protool 6.0 sp3.
Я успешно соединяюсь и загружаю проект.
Но после download панель выдает "setup default prog" и сбрасывается в стандартный проект по умолчанию.
Сравнение версий показало, что в протуле прошивка стоит 1.00, а панель выпущена позже и в ней прошивка 2.09.
Как мне прошить эту панель?
подойдет ли для моих целей программа comtext?
1. чем можно прошить кроме протула(где будет новая прошивка)? после поиска понял что есть программа comtext, но по ней нашел мало информации, где ее скачать? будет ли там более новая прошивка?
2. можно ли где-то найти новую прошивку для op3 и загрузить ее в протул?
Заранее спасибо!
In English:
Hi All!
I want to upload a project through OP3 protool 6.0 sp3.
But after the download OP3 shows "setup default prog" and reset to default project.Version firmware in protool is 1.00, and in the panel 2.09.
How do I download this panel? Where can i find new firmware?
Can i use for this comtext ? (Do comtext have the new firmware?)
Post by sania » Sat Mar 23, 2013 9:15 am
try update to hotfix 3 from viewtopic.php?f=36&t=5673
comtext very old software check viewtopic.php?p=6520#6520
try compile project & check for errors
попробуй обновиться до хотфикса 3
комтекст старее чем протул
какой зак. номер ор3?
попробуй скомпилировать проект и посмотреть есть ли ошибки
