upgrade wincc with sp2 to sp4
Ulkucu_Hareket
Post by Ulkucu_Hareket » Mon Jul 31, 2006 3:38 pm
privet...
friends..i have wincc with sp2 and i want to upgrade it to sp4.....i installed sql4 but i cannot upgrade wincc...bcs when i put the wincc sp4 cd ,it says u should put ms-tools cd and u should install security patch..and so i put ms-tools cd and i try to install security patch..but it says and error message that ""Setup cannot uptade your Windows XP files because the language installed on your system is different from the uptade language"
what is the problem?where is the false? and what should i do.....and also i checked languages of wincc and ms tools patch language..its same and its english... :?
lc001
ms patch
Post by lc001 » Tue Aug 22, 2006 9:23 am
you cannot do it because this pacth didnt published in turkish. yani türkçesi windowsu ingilizce kuracaktın dostum :)
Guest
Post by Guest » Tue Aug 22, 2006 12:45 pm
http://www.microsoft.com/downloads/deta ... laylang=tr
i just relooked to updates and its available now for download.
