TP1500 Master and TP1500 Slave (mirror)
lukas13
Post by lukas13 » Fri Nov 18, 2022 11:54 am
I have such a Problem. I’m working with two TP1500. One of the is the master with the IP address (10.100.100.102). The second one should be the slave IP (10.100.100.103). The slave should work like a mirror for the Master for that I’m using Smart client view. For that is everything working fine.
I can also see how the data are displaying on booth machine so they have an access to the memory card. But in my project I have also a storage for the shift. And there come my Problem. If I am using just the main screen everything appears correctly but if I press connect on the Slave screen. I probably can’t access the memory card. And the working shifts will not appears. Does anyone have solution for this problem or any good Idea what can cause the Problem? The slave screen is without any Scripts or variable.
Thank you very much.
