Visual Basic Script to excell
mike347
Post by mike347 » Tue Feb 23, 2021 2:15 am
Tia Portal v15.1
How can I put the date and time in an Excel file with a Visual Basic script?
Can you help me??
Greetings
Rex2701
Re: Visual Basic Script to excell
Post by Rex2701 » Tue Feb 23, 2021 2:00 pm
stackoverflow.com helps you:
Set objExcel = CreateObject("Excel.Application")
Set objWorkbook = objExcel.Workbooks.Open("Your_Excel_File.xls")
objExcel.cells(1,1).value = "Test value"
objWorkbook.Save
objWorkbook.Close
But it is a pure VBS example. I have no idea does TIA supports the "CreateObject" directive or not.
