Good afternoon. There is a virtual machine on which tia portal v15.1 is installed. I create a trial application on plc1200 as well as create visualization on wincc professional. I run no communication in the simulator. But if instead of wincc professional I create an hmi socket, everything works. The strange thing is that if instead of plc1200 using plc1500 then everything works with both the hmi panel and wincc professional. Did someone have something similar? What is the problem with this behavior?
Добрый день.имеются виртуальная машины на которой установлена tia portal v15.1 . Создаю пробное приложение на plc1200 так же создаю визуализацию на wincc professional.запускаю в симуляторе связи нет.но если вместо wincc professional создать hmi панельку то все работает. Странно то что если вместо plc1200 использовать plc1500 то все работает как с hmi панелью так и с wincc professional.у кого то было что то похожее?в чем проблема такого поведения?
Wincc professional v15.1(tia) and plc1200 (simulation)-edited
Re: Wincc professional v15.1(tia) and plc1200 (simulation)
Did you enable the PUT and GET in S7-1200?
If not, try to enable ir and test.
Go to the properties of the CPU -> protection and here you can enable the possibility to use PUT and GET instructions from another partner.
Best regards,
Best regards,
thanks for the answer,yes, this property is included.
Re: Wincc professional v15.1(tia) and plc1200 (simulation)-edited
I sort of figured it out, the problem is in tia15.1 itself, I tried this configuration on tia14, everything works
