Comparison of tags in WinCC 2008 application
jamesd556
Post by jamesd556 » Fri Apr 03, 2020 1:11 am
As part of a college assignment on developing a simple HMI application for control of a VSD and motor in WinCC Flexable 2008 I've been asked to show a the status of the motor in text, I am trying to use a symbolic IO filed with a text list but I need to show the following values;
If the motor is stopped: Stopped
If the motor is running at less than 75% of the setpoint: Starting
If the motor is running greater than or equal to 75% of the setpoint: Running
I have 2 memory words; MW10 and MW20
MW10 is the setpoint of the VSD on a scale of 0 - 100
MW20 is the feedback from the VFD again converted to a scale of 0 -100
What is the best way to display the correct value in the IO field / text list?
I can't seem to find any default tool that will allow me to do a comparison of 2 MW tags.
Is the best approach to do the comparison in a script and output the result on a single-digit that can be used in a text list?
Thanks, James
