It is currently Wed Jan 23, 2019 10:34 am
PostPosted: Mon Apr 24, 2017 10:20 pm
In general, this control PLC program is written in GX Works. I did a simple visualization on TIA Portal v14 (WinCC RT Advanced) and I would like to now test it on Mitsubishi FX3U driver with ENET Module.
I do not have much experience in this kind of thing, I'm still learning. I know that someone previously made a visualization in LabView and downloaded the tags from the PLC using NI OPC Server. Someone also did visualization in iFix and also downloaded tags through server opc.
I do not know just how or what program to download tags in PLC so that I can no longer use it in visualization in TIA Portal.
Unfortunately I still have a connection problem. The driver is connected to the router. From the connection options with RT Advanced I chose in the connections tab Mitsubishi and entered the appropriate IP. Still nothing.
I do not know if the lack of a connection can be related to a virtual machine (VM Vare Workstation 12) on which I have TIA Portal installed. The driver pings but can not connect. I also tried using KEPServer EX to connect and unfortunately also failed. (I have information about the can not connect).
Anyone know what program I should use? or had contact with such a problem? I attach a photo of communication from my station to more visualize the problem.
Users browsing this forum: No registered users and 4 guests
