It is currently Sun Jan 21, 2018 3:57 pm
PostPosted: Fri Mar 25, 2016 10:02 pm
I have made a project with siemens PLC SIMATIC S7-300, CPU 313C integration with Protool for ink dispensing system. i just put manually ink required value in kilogram in datablock and compare it with actual value which i get through weighing scale, which is working fine
Now i want to connect this system with another software from where i can get the ink required value in auto mode CxF file format.
so i want to know how can i transfer the value from file to my DB data block used for required ink input value. so that when i received these values from that software it will transfer to my PLC input data block and my system will work as per that.
