PLC Moeller and Wincc
Ali_Reza
Post by Ali_Reza » Sun Oct 18, 2015 11:45 am
Hello
I used Wincc 7.0 for visualization Moeller PLC data via Ethernet (TCP/IP) . I can connect to Wincc and see tag value . but after few minutes tag can not be Update and be disconnect .
I use Moeller OPC server .
so what is Problem ?
