WinCC + Matrikon OPC (Redundancy)
Hilss
Post by Hilss » Fri Apr 03, 2015 6:32 am
Good afternoon.
I have 2 questions:
Question 1 - How to connect WINCC redundant to the connection that is created in Redundancy Broker? If SCADA and Redundancy Broker installed on a single machine to establish a connection succeeds. But if on different problems arise. I have Windows XP SP2. Used the manual on the link https://www.matrikonopc.com/downloads/1 ... index.aspx. It didn't help.
Question 2: is it possible to connect to the redundant connection that is created in Redundancy Broker using WINCC 7.0 and above? To connect succeeded only WinCC 6.2
When I try to connect, the following message appears:
No access to selected OPC server
Details:
HRESULT 80040154
REGDB_E_CLASSNOTREG
