wincc v7.0 programe and license
moon_star
Post by moon_star » Fri Oct 24, 2014 12:45 pm
good evening
I made an example with pcs 7.1 and wincc v7.0 and made compile and download without errors
when I open and activate my programe from wincc programe it gives the following:
Tag Logging Run Time
36%
after that the programe stoped
and in the license authorisation information it gives the following:
SIFLA9WCP80700 wincc RC PO(20000) 300 tags present,limit is 20000 used by Configuration+Run Time+ Miscellaneous
after that when I want to close wincc programe it dosen't close and I try to shutdown my computer from start menu but it dosen't accept I turend it off from on/off pushbuton
Is there problem in my wincc software?????
