[?]: I need "MP377_V1_0_4_0.img" file
omar zedan
Post by omar zedan » Thu Jan 10, 2013 7:52 pm
Dear All
I need "MP377_V1_0_4_0.img" file which install with wincc flex (Siemens --> WinCC Flex -->WinCC Flex Images)
I will appriciate that so much.
Also how can I reset to factory settings? I select Reset factory setting and wrote the mac address of the panel but noting happend.
Umencho
Re: Siemens MP 377 12" Touch
Post by Umencho » Fri Jan 11, 2013 7:59 am
http://support.automation.siemens.com/W ... n/35677293
Basically the HSP for WinCC Flex is http://support.automation.siemens.com/W ... n/19241467
Which version of WInCC FLex do you have?
BR
omar zedan
Post by omar zedan » Mon Jan 14, 2013 8:02 am
Thank you very much
