[?]: Webclient and Wincc RT Pro
scarebyte
Post by scarebyte » Tue Nov 20, 2012 3:09 pm
I have a laptop pc with RT and webclient licenses.
I configure an RT project with 3 images and allow webaccess. Also configured dynamic login in runtime settings using this guide: https://support.automation.siemens.com/ ... #A59840669
I used wincc web configurator to create the web site, I assign port 80 and the internal ip of the pc(192.168.0.33).
I used windows IIS manager start the web server.
After that I used Wincc RT start to start the proyect.
In another pc of the same net , I go to 192.168.0.33 then a login windows appears ,I enter the user I configured in tia portal but it didnt accept the login. I can login using anonymous login setting of the IIS manager but then appears a page asying "The WinCC Server is currently not active".
Any idea?
Thanks.
