Hi All,
I want to archive a string tag in WinCC like other process tags in the tag logging.
[?]: How to Archive String tag in WinCC
saravanan_tsvk
alex_ros
Re: How to Archive String tag in WinCC
In the properties of each message (Alarm Logging), use the tabs "Tag / Action" (Process Value = StringTag) and "Text" (template: @ 1% s @). The value of the string tag will saved at Alarm On or Alarm Off.saravanan_tsvk wrote:Hi All,
saravanan_tsvk
Re: [?]: How to Archive String tag in WinCC
Thank you very much.
It is working fine.
It is working fine.
