[?]: vbs under WinCC 6.0 and Excel
PLC_ITA
Post by PLC_ITA » Wed Jul 06, 2011 6:02 pm
Hello , i need a help about a vbscript and excel.
Few years ago i wrote a script to save data in XLS format, and all ok. Into the system there are WIN XP SP2 - WinCC 6.0 SP4 and EXCEL 97.
Now i have only update excel to 2003 and my script does not work and i don't understand why.
If i delete excel 2003 and restore 97 , all ok
The script is locked when create object :
Dim FILE_EXCEL
Set FILE_EXCEL = CreateObject("Excel.Application")      <---- the script is locked during this instruction
FILE_EXCEL.Workbooks.Open file_name
Thi is the same script like into the help of WCC !!!
i'm not a big vbs programmer and i need a help from you !!! (sos)
thank you in advance
