[?+]: Transfering Asian project to hmi mp277 touch
Hi im Mike from Philippines (Southern and Eastern Asia) can you please help me to my problem we had a new hmi mp277 10" touch, when i transfer the project it cannot continue compiling and also when i test the runtime it cannot work also, but no message appeared on the screen.
Our program is original came from OEM japan the program is made from winccflex 2007 and i successfully transfer to 2008.
I set the configuration correct because i test it to other program and it work.
i had no idea where is my mistake i hope you can help me\.
Thanks and Best Regards!!!!!
Mike
Mike
Re: Transfering project to hmi mp277 touch
if you " had no idea" - upload your project in rapidshare,post link,any one can check it
Sir thank you very much for your attention tommorow i will upload the project to rapidshare.
Regards!!!
Mike
Regards!!!
Mike
Re: [?]: Transfering project to hmi mp277 touch
first try:
file -> compiler -> rebild all
Mike, if program was created in WinCC Flex 2007 and you are usng WinCC Flex 2008 to download it, I believe that you need to update Operating system first, since new panel image was delivered with WinCC Flex 2008.
Thanks homeroid_BL for your suggestion, I try that but it doesn't work ..
I try to rebuild all here is the massage appeared on the screen.
Sania here is the link of original program HMI including the PLC program came from OEM.
http://plcforum.uz.ua//6 ... progam.rar
S00:55:09.70 Compiler Info : 1% done, 7639 steps remaining ...
00:55:10.64 Compiler Info : 2% done, 7565 steps remaining ...
00:55:11.64 Compiler Info : 21% done, 6145 steps remaining ...
00:55:12.14 Compiler Info : 25% done, 5845 steps remaining ...
00:55:12.64 Compiler Info : 32% done, 5245 steps remaining ...
00:55:13.14 Compiler Info : 67% done, 2545 steps remaining ...
00:55:11.40 Compiler Info : 9% done, 7051 steps remaining ...
00:55:13.65 Compiler Info : ### FAILED with 2 error(s), 0 warning(s).
00:55:08.92 Compiler Info : Compiling 22 delta steps ...
00:55:13.65 Compiler Info : Compiling finished!
00:55:08.92 Compiler Info : Compiling started ...
00:55:13.65 Compiler Error : Invalid symbol assignment for area pointer 'Job mailbox'.
00:55:13.65 Compiler Error : Invalid symbol assignment for area pointer 'Screen number'.
00:55:13.14 Compiler Info : Linking target 'デバイス_1' ...
00:55:13.14 Compiler Info : Number of generated tags: 78.
pack & upload again i have problem with unrar
try winrar 4 http://rarlab.com/download.htmsania wrote:pack & upload again i have problem with unrar
http://plcforum.uz.ua//6 ... progam.zip
and delete file LANGUAGE in folder Global
but this project is for Asian versions
Mikel_010201,
see under Communication/Connection, tab 'Area pointers' (next to 'Parameters' tab).
Your problem is there.
Rename some Japanese names (=Invalid symbol) to English (valid symbol)00:55:13.65 Compiler Error : Invalid symbol assignment for area pointer 'Job mailbox'.
and reconnect DB33 and DB34
after this project work
Re: [?+]: Transfering Asian project to hmi mp277 touch
Thanks To all, I will try these when i goes back to work and ill give you an update .
Thanks and Regards!
Mike
Thanks and Regards!
Mike
Hello to all
Thank you for helping me now i reslove the problem your all correct,thank you guys
