[?+]: How to copy WinCC 6.2 application program
amit
Post by amit » Wed Jan 05, 2011 1:56 pm
Dear Friend Hi,
How we can copy application program/ configuration from a PC where WinCC is intalled .
I have PC Where Wincc 6.2 is installed and application runs on it.
From recent file menu i got location of the application / configuration folder.
But if i tried to copy it ; message comes that this folder/ file is being used by other program and can not copied.
I even stoped WinCC RT and explorer but it gives same message.
Pl tell me procedure to copy this.
Amit
peterc101
Re: [?]: How to copy WinCC 6.2 application program/configura
Post by peterc101 » Wed Jan 05, 2011 3:48 pm
you need to open taskmanager and close all wincc processes running
after you will be able to copy
amit
Post by amit » Sat Jan 08, 2011 12:46 pm
Dear peterc101
Thank you very much. Your sol works fine.
Amit
Yury
Re: [?+]: How to copy WinCC 6.2 application program
Post by Yury » Tue Jan 11, 2011 3:30 pm
Also you can stop SQL SERVER (Start/Programs/Microsoft SQL server 2005/configuration tools/SQL server configuration manager/SQL server 2005 Services ), copy you program, then start sql server and start WinCC project
