[?]: the problem in setup wincc 7.0 sp2 in windows7
wuyounanhai
Post by wuyounanhai » Tue Sep 28, 2010 2:40 am
I downloaded wincc 7.0 sp2 last night,after i unzip the files,when i run "WinCC_V70_SP2_ASIA.exe",he told me "WinCC V7 could not be found.SIMATIC HMI Edition cannot be installed.",why? or I must install wincc7.0 low version before?
thanks a lot.
Umencho
Re: the problem in setup wincc 7.0 sp2 in windows7
Post by Umencho » Tue Sep 28, 2010 8:26 am
Downloading the Service Pack2 for WinCC/CAS V7.0:
The Service Pack is provided as a WinZIP archive. Download the file into a folder on your CAS-PC and then unpack the file "WinCC_V702_CAS.zip". Please note, that an already installed CAS has to be deinstalled before installing WinCC V7.0 SP2 / CAS.
Download WinCC_V70SP2_CAS.zip - https://support.automation.siemens.com/ ... d=45173675
Best regards
nhan209a
Post by nhan209a » Tue Sep 28, 2010 11:27 am
Please see this topic:
viewtopic.php?f=36&t=7825#p37967
With Mr. Link's instruction, you can fix your problems when running *.exe file.
wuyounanhai
Post by wuyounanhai » Fri Oct 01, 2010 5:01 pm
thanks a lot ,i have installed in my computer,but sucess affter twice,first installed 7.0 sp1,then unzip sp2 and save it,next time,you can install sp2 one times.
