It is currently Wed May 23, 2018 2:32 am
PostPosted: Sun Apr 22, 2018 11:14 am
Hello, everybody !
Do those buttons work at your configuration PC in Runtime ?
If yes, please indicate the TIA portal software (WinCC) you use.
I create the HMI project for TP1500 Comfort in TIA portal v.13 incl. WinCC Comfort/Advanced .
I configure the current trends in “Trend View” placed to correspondent screen.
I have no real PLC & OP so I only use PLCSIM and my configuration PC.
Why the buttons in Runtime :
►► (scroll forward) and ▐◄ (to beginning) are always inactive (grey) ?
◄◄ (scroll back) - although is active, but upon pressing nothing changes (time points on the time axis are not changed) ?
The same situation also takes place when I configure the “archive trends” (“Trend type” column = “Data Log” )
In WinCC Flexible 2008 everything is Ok and all buttons work in Runtime.
I have created my own buttons with functions upon pressing :
TrendViewScrollBack - also doesn’t work in Runtime
TrendViewScrollForward - also doesn’t work in Runtime
TrendViewBackToBeginning - also doesn’t work in Runtime
TrendViewCompress - also works in Runtime Ok
TrendViewExtend - also works in Runtime Ok
TrendViewSetRullerMode - also works in Runtime Ok
I have no idea what’s the matter.
Probably the problem is somewhere on system level ?
Regards.
