Page 1 of 1
[LINK]: Data Analyzer (Decoder) for FlexRT compiled.fwx/fwd
Posted: Fri Oct 24, 2014 2:40 pm
by Alex444
Program Analyzer for FlexRT - Wincc Flexible and TIA Portal Wincc basic/Comfort/Advanced
prints a list of the screens,
allows you to view the tags
alarms
and used images
Some Touch panels Siemens (not all) for which the development environment - Wincc flexible and may be the latest Protool.
Compiled project file - pData.fwx can take with OP
using a conductor WINCE or to make backup on the flash (this file is in the backup).
Russian wrote:Программа Analyzer for FlexRT- Wincc Flexible and TIA Portal Wincc basic/Comfort/Advanced
печатает список экранов,
позволяет просматривать теги ,
аварийные сообщения
и используемые изображения
некоторых Touch панелей Siemens (далеко не всех) , для которых среда разработки - Wincc flexible и может быть последние версии Protool.
Файл скомпилированного проекта - pData.fwx можно взять с OP
используя проводник WINCE либо сделать backup на флеш (этот файл будет в backup-е).
для использования с TIA Portal Wincc basic/Comfort/Advanced проектами надо переименовать их расширение *.fwc to *.fwx
https://mega.nz/#F!vo9yzCYD!C6kGZLiz301djW11la5dVw
and show internal images
for use with TIA Portal Wincc basic/Comfort/Advanced projects need rename extension from *.fwc to *.fwx
https://www.virustotal.com/ru/file/05ec ... 414173671/
HA256: 05ec892a7c8e47c90d0b856b962312ba27f63f45d405191ca59e5e95b354df6a
FlexRT.exe
virus not detected: 0 / 54
Re: [LINK]: Data Analyzer (Decoder) for FlexRT compiled.fwx
Posted: Thu Nov 27, 2014 9:16 am
by dekor
Dear friends,
please can you share with me the fonts that I need to insall on my computer in order to display correct the text for that application?
Thank you in advance,
dekor.
Re: [LINK]: Data Analyzer (Decoder) for FlexRT compiled.fwx/
Posted: Thu Dec 25, 2014 2:44 pm
by Draco Malfoy
Good afternoon!
First of all I want to thank you for your hard this software, we are waiting for it for years and not chayali that something similar will. Since Siemens can do everything except how to handle Projects compiled their own software. Probably because in this case they will have to admit the failure of protection methods Know-how because of what the potential clientele can stand on its hind legs.
There are a couple of questions: let's say I have a certain localize the input field, symbolic or numeric. And I want to see the associated variable. How to do it? Cross-references I somehow do not work. Panel MP370, ProTool v6.0. Thanks in advance!
Another question: is absolutely impossible to see error messages. They are there in the panel about a few hundred, but the text is not visible at all but only the tags that are attached. thanks in advance
Russian wrote: Добрый день!
В первую очередь хочу усиленно поблагодарить вас за эту софту, мы её годами ждали и не чаяли что что-то подобное будет. Поскольку Сименс умеет всё, кроме как обращаться с проэктами скомпилированными их же ПО. Вероятно, поскольку в этом случае им придётся признать несостоятельность методов защиты Know-how из-за чего потенциальная клиентура может встать на дыбы.
Есть пару вопросов: вот допустим я локализировал определённое поле ввода вывода, символическое или цифровое. И хочу увидеть связанную с ним переменную. Как это сделать ? Перекрестные референции у меня почему-то не работают. Панель MP370, ProTool v6.0. Спасибо заранее!
ЕЩЁ вопрос: абсолютно невозможно посмотреть сообщения об ошибках. Их там в панели примерно несколько сотен, но текстов не видно вообще а только теги к которым привязаны. Спасибо заранее
Posted: Fri May 08, 2015 10:25 am
by SohrabB
Thank you for everything.
My question is: Can I change picture and edit text Message?
If I can, How?
Thanks Thanks Thanks ........................
Posted: Thu Jun 30, 2016 6:26 pm
by ryuvp
Re-upload file pleasee (oo) (oo)
Posted: Thu Jun 30, 2016 7:45 pm
by Update
Posted: Fri Jul 01, 2016 1:58 am
by ryuvp
Many thanks sir (tyou) (tyou) (tyou)
Very happy to get this FlexRT software (suc) (suc)
Just asking, any patch file or setting to make some word in the software readable ?
Posted: Fri Jul 01, 2016 7:42 am
by CoMod
see updated FlexRT_Readmy_rus_En.pdf
Posted: Sat Apr 14, 2018 12:00 am
by nikolay_i
Re-upload file, please
