It is currently Wed Nov 14, 2018 4:00 am
Post new topic Reply to topic  [ 20 posts ]
PostPosted: Wed Jul 04, 2012 8:50 pm
tools for view password in WINCC flexible pdata.pwl
for PC Windows and Windows CE 5.0
MS Framework is required for PC Windows
FlexPWL-это программа для просмотра и разблокировки паролей OP панелей SIEMENS .
Как известно пароли на OP ,где проект был создан на WINCC flexible
хранятся в файле pdata.pwl или pdata.pwl1,так что главное найти эти файлы.Так же есть вариант
программы под windows ce 5.0(операционная система панелей).
Cсылка :
FlexPwl.rar
https://mega.co.nz/#!eNURWY6a!juyKAx5uXHfidnr07fdTXuujq281dPvjFCRWLz3cdz0
http://f-bit.ru/369922
Select English
PostPosted: Thu Jul 05, 2012 2:06 pm
Good job! (clap)
PostPosted: Fri Jul 06, 2012 11:54 am
very useful, specially in old projects where i forget almost everything (included the passwords) :D
PostPosted: Thu Feb 20, 2014 10:18 pm
Новая ссылка : http://f-bit.ru/369922
PostPosted: Wed Feb 25, 2015 7:48 am
Dear all
thank you for your aid.
but how to find pass in wincc scada v7??
(gpost) (gpost)
PostPosted: Tue Jun 02, 2015 6:55 am
Hi, may I know how is the FWL file generated? I can't seem to find the FWL in the project folder after rebuilding the project
Regards,
wantutri
PostPosted: Sat Jun 27, 2015 9:34 pm
Dear all
how can I use this software??
PostPosted: Thu Dec 15, 2016 2:02 am
A tool for analyzing PWL / PWX files and extracting usernames and passwords:
https://mega.nz/#F!38BQ1bwR!3cxQJ0FdEUy5pPg9k5ZeKQ
PostPosted: Thu Dec 15, 2016 12:24 pm
FlexPwl viewtopic.php?f=37&t=18007&p=53968&hilit=FlexPwl#p53968 is also doing the work.
PostPosted: Mon Jan 16, 2017 3:47 pm
I've uploaded a new version of the tool, which also works with PWL files version 1.3 and 1.4 (TIA13 / 14).
The download link is the same (https://mega.nz/#F!38BQ1bwR!3cxQJ0FdEUy5pPg9k5ZeKQ).
PostPosted: Tue Jan 17, 2017 6:03 am
This would be very very nice!
PostPosted: Tue Jan 17, 2017 9:30 am
please use date in file name
PWLAnalyzer_2017_01_16
PWLAnalyzer_2016_12_14
and add MD5 checksum file - for example see Sim_EKB_Install_2017_01_17 viewtopic.php?f=30&t=218
PostPosted: Tue Jan 17, 2017 1:48 pm
Done:
PWLAnalyzer_2016_12_14.zip (MD5: 8382ed22dc0cce149ab5ef088a28aab5)
PWLAnalyzer_2017_01_16.zip (MD5: 38ab1cd7e84097839f35f1a57c358f39)
PostPosted: Thu Jul 06, 2017 12:14 am
works great on version 13 but doesn't show passwords on V14 SP1 only user names
Mel
PostPosted: Tue Jul 25, 2017 8:50 am
From version 14 you can no longer see the password, because the password is no longer stored in the file.
Only the password hash is stored; using the "Test/reset password..." function from "Password" menu you can test if a password corresponds to the stored hash.
You can also reset the password (by forcing a new hash).
PostPosted: Thu Jul 27, 2017 3:18 am
Could you please get the hash to viewer? With hash, we maybe found a correct password. Which kind of hash does it use?
Thank you.
PostPosted: Fri Jul 28, 2017 11:34 pm
You can view the hash from "Test/reset password..." dialog box (you can also copy-and-paste the hash as text).
The algorithm used is SHA256 (the password is also salted before hashing).
PostPosted: Mon Jul 31, 2017 6:40 pm
Thank you. The algorithm they used seems to be too strong.
PostPosted: Thu Apr 12, 2018 11:01 am
very good word
PostPosted: Sat Apr 14, 2018 3:04 am
Добрый день. Можно свежую ссылку на скачивание? Очень нужно
