It is currently Thu Jan 17, 2019 3:38 am
 Post subject: PLC resouce monitoring
PostPosted: Sat Aug 19, 2017 3:39 pm
Hi! I am looking SW for PLC resource monitoring: state (RUN/STOP), cycle time, memory use/free, communication, etc. Archiving and messaging is desirable.
p.s. VersionDog already in use.
PostPosted: Wed Aug 23, 2017 11:58 am
if your PLC can, Website give a lot of informations
PostPosted: Mon Sep 04, 2017 12:38 pm
Hi all
Did you have this one
https://www.versiondog.com/versiondog_f ... tatus.html?
Best regards,
sowieso
PostPosted: Sun Jan 21, 2018 7:23 pm
SIMATIC Automation Tool
After a control program is created and verified with the Siemens TIA Portal software, the SIMATIC Automation Tool can be used in the field for operating and maintaining SIMATIC S7-1200, S7-1500, ET 200, HMI, SITOP, RFID and MOBY Ident modules.
Automation Tool operations:
Scan an PROFINET/Ethernet network and identify all devices connected to the network
Flash device LEDs or HMI screens to physically locate a device
Create a table that maps the accessible devices on the network
Assign addresses (IP, subnet, gateway) and station name (PROFINET device)
Set the time in a CPU to the current time in your PG/PC
Download a program to a CPU (support failsafe programs needs at least V3.1) and HMI panels
Put a CPU in RUN or STOP mode
Perform a CPU Memory reset
Backup/Restore CPU or HMI data to/from a backup file (failsafe needs at least V3.1)
Upload service data from a CPU
Read the diagnostic log from a CPU
Reset a CPU to factory default settings
Update firmware in a CPU and attached modules
Upload, download, or delete Recipe data (stored at SMC) from a CPU
Upload or delete Data log data (stored at SMC) from a CPU
Document and save your network information
in a standard text .csv file or
an encrypted & password protected .sat file
API support to create custom applications based on the functionality available in the SIMATIC Automation Tool
All named features can operate in parallel to various CPUs.
