Automatic Backup Tool for all S7 PLCs
Utilites for Simatic Automation
lex1993
Post by lex1993 » Wed Aug 02, 2017 6:34 am
Hello!
At my firm we have great amount of different S7 PLCs (300, 400, 1200, 1500..) and we would like to perform automatic backups of all PLCs at specific time intervals. Does any of you know any Automatic Backup Tool that is capable of performing such action.
Actually I found an almost perfect tool for this: https://www.mhj-tools.com/buddy-for-s7/ (and I heard it does a good job). The only problem is that it only works for S7-300 and S7-400 PLCs and not on 1200 and 1500.
Also, if there is another way of performing automatic backup, I am open to any suggestions! Every information is helpful.
Thank you in advance for all your answeres.
Regards
xflash
Re: Automatic Backup Tool for all S7 PLCs
Post by xflash » Sun Aug 06, 2017 3:03 pm
TIA Portal has officially built-in this function. But I did not use it yet, do a test before using on-site.
Post by Dfcz » Tue Aug 08, 2017 10:15 am
I was dreaming about this for 15 years.
There are more PLCs 200 version, S5, M7, panel3 OP3, OP7 (many version).
And many-many PLCs and Panels other firms.
(h)
(read)
bazilio
Post by bazilio » Sat Aug 19, 2017 12:31 pm
Thera are good solution - VersionDog
https://www.versiondog.com/
Two kind of backup - offline source code and online programm. Sheduled task for reading online (from device), compare with versions (offline & previous online), show differenсes, open it in the develompent software (i.e. simatic manager).
Support a lot of kind PLC, HMI, CNC, PC software.
Price €30K+.
If you interestion expirience of use - write me.
