It is currently Sun Feb 19, 2017 7:36 pm
 Post subject: Tool to configure I/Os
PostPosted: Thu Jul 21, 2016 10:33 am
Hi to all,
I am looking for a tool to make the I/O distribution in my PLC. I have to configure a large system (about 1000 I/Os) with different logics (2oo3, 2oo2, 1oo1), so I have to distribute correctly the I/Os within modules and modules within racks to ensure it makes sense (e.g.: for 2oo3, each of the 3 channels should be in different racks, etc).
How you make this? I have always made this manually but when there are many I/Os it can take a lot of time and risk of mistakes is high.
Thanks for your support.
Note: I am new in this forum. Congratulations to organizers and administrators. Good job.
PostPosted: Thu Jul 21, 2016 12:56 pm
http://w3.siemens.com/mcms/topics/en/si ... s/tab.aspx ?
PostPosted: Thu Jul 21, 2016 1:55 pm
I know well TIA portal from Siemens but it is a product oriented tool , you can select the right hardware (IO modules, CPU, chassis, communication modules, etc.) but as far as I know you can not make a detailed I/O distribution of redundant signals to build a consistent architecture.
What I'd need is a engineering oriented tool , not related to the hardware. I don't know if this kind of tool really exists.
Thanks in any case.
PostPosted: Wed Aug 24, 2016 11:34 am
Their is a tool from Siemens called ProTime.it is used for the configuration of the system in the engineering phase..
but you are using PCS7 or normal step 7 programing tool or TIA Portal?
PostPosted: Tue Sep 20, 2016 9:41 am
Hi, I have taken a look to Protime but it's not what I was looking for.
But I found a very amazing tool that I am using and it really works very well. The tool itself is called IO Builder (http://plcdesign.xyz/en/io-builder/) and is based on Excel.
Thank you for your support.
