It is currently Mon Jan 21, 2019 1:02 am
 Post subject: [?]: Simatic ET 200S CPU
PostPosted: Fri Apr 01, 2016 2:19 pm
Hello,what are the feasible conditions for selecting Simatic ET200S CPU??
In some article, I saw its better for stand alone systems..
here stand alone means redundant.
Isn't it??
Please explain it....thanks in advance... (fback) (fback)
PostPosted: Mon Apr 11, 2016 12:31 pm
I believe that "stand alone" means not connected to other systems. Since you don't have DP (you need to buy additional module) or MPI on ET200S CPU can be considered not to be suitable for connection to the other systems.
You can use it if you don't need some special modules which doesn't exist for ET200S (I guess there are such), if processing speed and memory resources are satisfactory, and most important if someone (ie. customer (not_allow) ) is against its usage.
Best regards.
PostPosted: Mon Apr 11, 2016 4:49 pm
Best regards.
Thanks #bosandzeros, for your kind reply (thnx) ...But 6ES7 151-7FA20-0AB0 has the MPI+DP I/O and it can be used in hazardous situations also......Can you elaborate the term 'Special modules'..In this case we don't need safety module also......Thanks in advance.... (pm)
