[?]: Siemens PLC - simulator
Utilites for Simatic Automation
stanic
Post by stanic » Fri May 18, 2012 7:58 pm
Is there any simulator for siemens step 7 v5.5, which works on win 7 32 bit ?
Contact:
Re: [?]: Siemens PLC - simulator
Post by CoMod » Fri May 18, 2012 10:19 pm
PLCSIM inside Step7 Professional 2010 SR2
viewtopic.php?f=30&t=13500
stanic
Post by stanic » Sun May 20, 2012 9:21 pm
Name of simulator is "S7_Plcsim_v5_4_SP5_x32_x64",but I am having problems while installing.
There is message to shut down some proceses in system32,can somebody help me ?
KortexX
Post by KortexX » Fri Nov 09, 2012 8:37 pm
you can use WinAC RTX 2010 or WinAC RTX F 2010 if you have a safety program.
You have to insert a new Simatic 300 station to your Step7 Prog. Copy in it your PLC prog. Load your virtual PLC as you do with others PLC.
