[?]: cpu 313c with sd card
Utilites for Simatic Automation
maher
Post by maher » Wed Sep 28, 2011 12:01 pm
Hi all,
I have cpu 313c with sd card, but when I put it in the sd/mmc card port of my pc, but the pc didn't recognize on it.
I use another sd card but the pc saw it.
so what can i do?
regards,
Maher
Contact:
Re: [?]: cpu 313c with sd card
Post by CoMod » Wed Sep 28, 2011 9:01 pm
This is special edition of MicroMemoryCard with Siemens special format - it incompatible with Windows.
Which memory cards can you use with a S7-300 CPU?
http://support.automation.siemens.com/W ... n/19102565
if you already formatted in Windows - use WinHex with image of original card for restore Siemens special format.
