E-Designer. E700 Beijer electronics
другие контроллеры
Guest
Post by Guest » Mon Dec 26, 2005 9:49 am
Все привет!
У кого есть E-Designer 6-й или 7-й версии для программирования панелей Beijer Electronics? Поделитесь плиз. Если есть 6-й версии, но нет желания давать его полностью, дайте плиз файл SYSLOAD.EXE. Мне нужно обновить прошивку, но к сожалению, у меня не полный пакет. Дайте ссылочку плиз! Очень нужно! Если файл не сильно большой, то можете заслать на cdmax2002@mail.ru
Заранее благодарен.
brave_eagle
Post by brave_eagle » Sun Jan 01, 2006 1:54 pm
if you can write in English, maybe I can help you, I cannot read Russian
Translate
Post by Translate » Sun Jan 01, 2006 7:39 pm
All greetings!
At whom is E-Designer 6-th or 7-th versions for programming panels Beijer Electronics? Share please. If there are 6-th versions, but there is no desire to give it completely, give плиз file SYSLOAD.EXE. I need to update an insertion, but unfortunately, for me not a full package. Give a reference please! It is very necessary! If a file not strongly big can send on cdmax2002@mail.ru
Thankful in advance.
brave_eagle
Post by brave_eagle » Tue Jan 03, 2006 2:43 pm
Is that means a sysload.exe file is OK for you?
YES
Post by YES » Tue Jan 03, 2006 5:06 pm
YES
brave_eagle
Post by brave_eagle » Wed Jan 04, 2006 1:31 pm
This file is not a part of E-designer, it belongs to the software HMI Tools which is used for download the system (*.bin) file to the panel?
It is right? Is it what you want to get?
