PLC FATEK not running program
другие контроллеры
hoanganhhao
Post by hoanganhhao » Fri Mar 10, 2023 1:11 am
I uploaded the program PLC FATEK A, then downloaded the program to PLC FATEK B and put it into the machine, it was not able to be controlled. Is there some hidden BIT condition?
mohdabshr
Re: PLC FATEK not running program
Post by mohdabshr » Sun Mar 12, 2023 1:47 pm
Hi my friend
there different in fatek plc if only upload program you may miss data , so the best way is make backup
and this backup will return every things to it position when you make backup.
what you said it happend to me so alawys i make bothe upload and backup.
thanks,
mohdabshr
Post by mohdabshr » Sun Mar 12, 2023 1:49 pm
dear
make backup for fatek A, and then Restore it to Fatek B and then A&B will be identical.
thanks,
hoanganhhao
Post by hoanganhhao » Mon Mar 13, 2023 7:45 am
dear
thanks,
Thank you for your response, I am currently doing the upload for the PLC: FBs-32MCT2-AC. And I can't find a backup for it. Can you suggest me software to backup ?
mohdabshr
Post by mohdabshr » Mon Mar 13, 2023 7:59 am
it is same winproladder, first go online and then go to tool and choose system backup and after you do your backup and then restore it to plc.
thanks,
hoanganhhao
Post by hoanganhhao » Mon Mar 13, 2023 9:15 am
thanks,
I have done it, 99% success, tomorrow I will check it again. Thank you very much
