Schneider Machine Expert V1.1 - Controller assistant Firmware - V5.0.2.70
другие контроллеры
ojars
Post by ojars » Mon Oct 03, 2022 3:34 pm
Hello Everyone.
Issue with Schneider electric Machine Expert V1.1. Thats what I am using right now.
However my ''version''' has only option to select choosing PLC' with firmware 5.0.2.70 when creating new project.
But Controller assistant does not have 5.0.2.70 firmware to update Controller.
Reason I dont have Firmware could be, because I installed SOMACHINES after I installed Machine expert, So I assume I have deleted thos firmware versons.
I know that schneider does not have any standalone firmare files after V4.0.6.42 (That is the latest version and meant for those who still use SOMACHINES (To downgrade PLC firmware).
Can enyone upload 5.0.2.70 firmware from PLC and share?
Or are threse standalone firmwae files? (.SECO or .bpd)
ojars
Re: Schneider Machine Expert V1.1 - Controller assistant Firmware - V5.0.2.70
Post by ojars » Fri Dec 02, 2022 6:33 pm
So I still havent manged to find a V5.0.2.70 firmware version!
But I got a Controller with a V5.0.8.40 firmware, and uploaded a firmware file from it.
Then I transfered the files to a SD card. And from SD cart flashed PLC with V5.0.8.40 firmware.
Now, the PLC is V5.0.8.40!
When making a new project in Schneider Machine Expert V1.1, I choose the V5.0.2.70 firmware and its possible to upload this project to a PLC with higher firmware version!
Not a complete victory, but at least something.
