Delta PLC explicit messaging!
другие контроллеры
totaj1
Post by totaj1 » Tue May 31, 2022 7:35 am
Hello I’m trying to control Powerflex 525 with a Delta AS series PLC, I’m using explicit messaging methode, I can read data from Powerflex for example nominal voltage etc, but I can not write or set new value to some parameters for example : ” Commanded Freq b002 ” and ” Drive Status b006 “. If anyone could help with this problem I would really appreciate it. Here are some photos of an example of the code!
https://drive.google.com/drive/folders/ ... UiplrSeLjF
Thank you in advance!
