If someone needs the standard in the version from 24/02/2017 look here:
https://pan.baidu.com/s/1eSf4mfo?fid=876204968222531
@Moderation: pls reupload / proceed to the correct forum, if neccesary. thanx!
VASS V05
linuxforever
Re: VASS V05
Thanks for you information.but acturally .this standard is out of date,The latest version is VASS 06Draco Malfoy wrote:If someone needs the standard in the version from 24/02/2017 look here:
Draco Malfoy
Re: VASS V05
@linuxforever
You are wrong. VASS 05 is still in Use by VW, AUDI, MAN and other manufacturers. VASS 06 is merely in the phasing-in periode.
E_L_V_I_S123
Re: VASS V05
The file doesn't exist. (((Draco Malfoy wrote: Sun Jan 20, 2019 11:11 am If someone needs the standard in the version from 24/02/2017 look here:
Do you have another link?
