It is currently Tue Jan 22, 2019 5:50 am
PostPosted: Mon Dec 03, 2018 11:15 pm
i have some trouble during attempt to connect via ethernet to my TBOX TG2-500.
If I connect through the usb using his address there is no problem the webpage appear if I surf to 10.8.10.1.
The tg2 setting is : ip 10.1.1.248 subnet-mask 255.255.255.0 gateway 10.1.1.1
The other network setting on the TBOX are the setting of default .
I tried with advanced ip scanner on the ip 10.1.1.248 , in fact it show me that exist a host with this ip and with Mac address equal of the TBOX.
The TBOX is connected to a router through a ethernet wire and there is another ethernet wire between router and my pc.
If I go with my browser to 10.1.1.248 it show me a error message.
How can I fix this ? There is a standard sequence of steps to be performed to be able to connect with my pc to tbox through a router ?
There is some setting that I have to change on my computer ?
Users browsing this forum: No registered users and 6 guests
