It is currently Wed Jul 18, 2018 11:55 am
PostPosted: Tue Feb 06, 2018 5:44 pm
Hi, guys,
the problem is: Mitsubishi PLC FX2 64M with 2 red LED flashing -low battery and CPU; battery replaced, but CPU alarm persist. Connected to the PLC with GX Developer, using diagnostic of PLC revealed error 6402 (PARAMETER ERROR). In the HELP it says that the Managing Method is "stop the PLC, SELECT THE PARAMETER MODE, SET THE CORRECT PARAMETER" - CAN SOMEBODY ADVISE HOW EXACTLY TO DO THAT?
PostPosted: Mon Feb 12, 2018 10:59 am
You have a memory capacity error.
This means the memory is set different to what is in the plc
The default is 8000 steps - check that
PostPosted: Mon Feb 19, 2018 10:18 pm
Hi, Ronnie,
thanks for your reply.
Problem was solved by clear the memory and download the backup.
Users browsing this forum: Google [Bot] and 11 guests
