It is currently Fri Jan 18, 2019 5:05 pm
Post new topic Reply to topic  [ 2 posts ]
PostPosted: Fri Dec 29, 2017 3:40 pm
Location: No.7, Xia Xianghu Road, Xiaoshan District, Hangzhou City, 311203, Zhejiang Province, China
ABB has over 20 years of experience in designing, installing and maintaining fault tolerant systems, both on and offshore. Safety systems have been supplied to the world’s premier companies in oil and gas, petro-chemicals, fine chemicals, aerospace and power generation. Applications include emergency shutdown, fire and gas, burner management, electricity distribution control, rocket launch control and many other of the most safety, environmental or cost critical control requirements.
P8100 Trusted Controller Chassis
P8110B Trusted TMR Processor
P8110C Trusted TMR Processor Conformal Coated
P8120 Trusted TMR Processor Interface Adaptor
P8121 Trusted TMR Processor Interface Adaptor (IRIG-B)
P8122 Trusted TMR Processor Interface Adaptor (MODBUS Master)
P8123 Trusted TMR Processor Interface Adaptor, (IRG-B and MODBUS Master)
P8151B Trusted Communication Interface
P8151C Trusted Communication Interface Conformal Coated
P8153 Trusted Communication Interface Adaptor
P8160 Trusted TMR Interface Modules
P8161 SC300E Bridge Module 001-1204
P8162 CS300 Bridge Module 099-1423
P8191 Trusted Shield, (For I/O and Communication Modules-Single Slot)
P8192 Trusted Shield (To fit Power Supply Module Location
P8193 Trusted Shield (For Controller Module-Triple Slot)
P8194 Shroud Kit for P8290 or P8297
P8200 I/O Power Supply Chassis 110-240 VAC
P8202 I/O Power Supply Chassis 24 VDC
P8220 Power Supply Module, 110-220 VAC, Dual In 15 VDC Out
P8222 Power Supply Module, 24 VDC, Dual In 15 VDC Out
P8225 Trusted Power Supply Module 110-240V dc dual in, 24VDC out
P8230 Power Shelf, (incl. 4U Mounting K
P8231 Power Pack 24VDC (system)
P8232 Power Pack 28VDC (field)
P8233 Power Port
P8234 Power Controller
P8235 Power Shield
P8240 Power Shelf Type II
P8243 Power Port Type II
P8247 Power Shelf Support (pair)
P8270 24V dc Fan Assembly, Rack Mounting (Includes 1-off P8273)
P8271 Trusted Fan Tray 24V dc Roof Mounted
P8272 Trusted Vent & Baffle Unit for Fan Assembly
P8273 Grill for Fan Assembly, Rack Mounting
P8290 Output Power Distribution Module
P8292 Power Distribution Unit, MCB 24V dc
P8293 Power Distribution Module 15 Way Fuse
P8294 Power Distribution Unit, Regent Interface
P8300 Trusted Expander Chassis
P8310 Trusted Expander Processor
P8311 Trusted Expander Interface
P8312-4 Trusted Expander Interface Adaptor-4 Way
P8312-7 Trusted Expander Interface Adaptor-7 Way
P8314 Trusted Fibre TX RX Unit
P8380 Chassis Panel Rear Mounting Kit
P8402 Trusted Dual 24V dc Digital Input-60 channel
P8403 Trusted TMR 24V dc Digital Input-40 channel
P8423 Trusted TMR 35-120V dc Digital Input-40 channel
P8424 Trusted TMR 120V ac Digital Input-40 channel
P8431 Trusted TMR Analogue Input-40 channel
P8432 Trusted Dual Analogue Input-60 channel
P8433 Trusted TMR Isolated Analogue Input-20 channel
P8448 Trusted TMR Zone Interface-40 channel
P8449 Trusted TMR 24V dc Valve Monitor-20 Valves
P8451 Trusted TMR 24V dc Digital Output-40 channel
P8461 Trusted TMR 24/48V dc Digital Output-40 channel
P8471 Trusted TMR 120V dc Digital Output-32 channel
P8472 Trusted TMR 120V ac Digital Output-16 channel
P8480 Trusted TMR Analogue Output-40 channel
P8800 Trusted 40 channel 24V dc Digital Input FTA
P8801 Trusted 40 channel 24V dc Digital Input FTA, Non-incendive
P8802 Trusted 60 channel 24V dc Digital Input FTA
P8805 Trusted 60 channel 24V dc Digital Input FTA, Non-incendive
P8821 Trusted 40 channel 120V dc Digital Input FTA
P8824 Trusted 40 channel 120V ac Digital Input FTA
P8830 Trusted 40 channel Analogue Input FTA
P8831 Trusted 40 channel Analogue Input FTA, Non-incendive
P8832 Trusted 60 channel Analogue Input FTA
P8833 Trusted 20 channel Isolated AI/DI FTA, Loop Powered
P8835 Trusted 60 channel 24V dc Analogue Input FTA, Non-incendive
P8840 Trusted 8 channel Temperature VFTA
P8842 Trusted 40 channel Universal Versatile FTA
P8846 Trusted 9 channel Speed Input FTA
P8850 Trusted 40 channel Analogue or Digital Output FTA
P8870 Trusted 32 channel 120V dc Digital Output FTA
P8871 Trusted 16 channel 120V dc Digital Output FTA
P8891 Trusted 2 channel High Integrity Relay Output FTA
P8901 VFTA Fuse/Link Pack (10 off 50MA, 10 off 315MA & 10 off 2A)
P8902 FTA, 40 channel, Fuse Pack (10 off 50MA)
P8903 FTA, 60 channel, Fuse Pack (10 off 50MA)
TC-001-02 Chassis Power cable
TC-002-02 Power cable P8292 to P8293
TC-003-02 Power cable P8293 and input FTA
TC-004-02 Power cable, P8293 and Input VFTA
TC-006-02 Chassis Smartslot Link Cable
TC-011-02 Fan Power cable
TC-201-02 I/O Companion Slot, Internal, 40 channel Input to FTA, PVC
TC-203-02 I/O Companion Slot, External, 40 channel Input to FTA
TC-205-02 I/O Companion Slot, Internal, 40 channel Output to FTA
TC-207-02 I/O Companion Slot, External, 40 channel Output to FTA
TC-209-02 I/O Companion Slot, Internal, 40 channel Output to VFTA
TC-210-02 I/O Companion Slot, External, 40 channel Output to VFTA
TC-211-02 I/O Companion Slot, Internal, 40 channel Input to VFTA
TC-212-02 I/O Companion Slot, External, 40 channel Input to VFTA
TC-221-02 I/O Companion Slot, 16 channel, ac Output to FTA, Integral Power
TC-301-02 Local Expansion Cable
TC-302-02 Remote Expander Cable (Controller End)
TC-303-02 Remote Expander Cable (Expander End)
TC-304-01 Trusted Remote Expansion Cable EXP END
TC-305-01 Trusted Communication Cable FL
TC-306-02 Input SmartSlot Jumper Cable
TC-308-02 Output SmartSlot Jumper Cable
TC-311-02 Local Expansion Cable Assembly, 1 way
TC-312-02 Local Expansion Cable Assembly, 2 way
TC-313-02 Local Expansion Cable Assembly, 3 way
TC-314-02 Expander Extension Cable, Single Slice
TC-320-01 Trusted Interface Cable
TC-323-01 Power Shelf Interconnect
TC-501-02 I/O SmartSlot, Internal, 40 channel Input to FTA
TC-503-02 I/O SmartSlot, External, 40 channel Input to FTA
TC-504-02 I/O SmartSlot, External, 40 channel Input to Flying Lead/Freewire
TC-505-02 I/O SmartSlot, Internal, 40 channel Output to FTA
TC-507-02 I/O SmartSlot, External, 40 channel Output to FTA
TC-509-02 I/O SmartSlot, Internal, 40 channel Output to VFTA
TC-510-02 I/O SmartSlot, External, 40 channel Output to VFTA
TC-511-02 I/O SmartSlot, Internal, 40 channel Input to VFTA
TC-512-02 I/O SmartSlot, External, 40 channel Input to VFTA
TC-517-02 I/O SmartSlot, External, 40 channel Output to FTA, Integral Power
TC-601-02 I/O SmartSlot, Internal, 60 channel Input to FTA
TC-701-02 I/O Companion Slot, Internal, 60 channel Input to FTA
TC-801-02 I/O Companion Slot, Speed Monitor to FTA (internal)
P8100C,P8120C,P8121C,P8122C,P8123C,P8153C,P8231C,P8232C,P8240C,P8293C,P8300C,P8310C,P8311C,P8314C,P8403C,P8424C,P8431C,P8432C,P8433C,P8448C,P8449C,P8451C,P8461C,P8471C,P8480C,P8800C,P8801C,P8830C,P8831C,P8833C,P8842C,P8846C,P8850C,P8891C,P8312-4C,P8312-7C,P8131,P8173,P8444,P8834,P8841,P8295,P8296,P8297,P8201,P8226,P8086,TC322-02,TC324-02,TC325-02,TC-310-02,TC-321-01,TC-322-02,TC-324-02,TC-325-02,TC-521-02
PostPosted: Sat Sep 15, 2018 1:46 pm
If you have the technical questions, please send to meverickcn@hotmail.com
Users browsing this forum: No registered users and 15 guests
