It is currently Fri Oct 19, 2018 11:00 pm
PostPosted: Fri Mar 17, 2017 10:50 am
Location: No.7, Xia Xianghu Road, Xiaoshan District, Hangzhou City, 311203, Zhejiang Province, China
Trustedā„¢, the ICS Triplex flagship product, has the smallest footprint in the industry. It uses RunSafeā„¢ 3-3-2-0 fault-tolerant control to virtually eliminate spurious trips and offers the highest availability and lowest cost of ownership of any SIL3 rated safety system available.
T8100 Trusted Controller Chassis
T8110B Trusted TMR Processor
T8110C Trusted TMR Processor Conformal Coated
T8120 Trusted TMR Processor Interface Adaptor
T8121 Trusted TMR Processor Interface Adaptor (IRIG-B)
T8122 Trusted TMR Processor Interface Adaptor (MODBUS Master)
T8123 Trusted TMR Processor Interface Adaptor, (IRG-B and MODBUS Master)
T8151B Trusted Communication Interface
T8151C Trusted Communication Interface Conformal Coated
T8153 Trusted Communication Interface Adaptor
T8160 Trusted TMR Interface Modules
T8161 SC300E Bridge Module 001-1204
T8162 CS300 Bridge Module 099-1423
T8191 Trusted Shield, (For I/O and Communication Modules-Single Slot)
T8192 Trusted Shield (To fit Power Supply Module Location
T8193 Trusted Shield (For Controller Module-Triple Slot)
T8194 Shroud Kit for T8290 or T8297
T8200 I/O Power Supply Chassis 110-240 VAC
T8202 I/O Power Supply Chassis 24 VDC
T8220 Power Supply Module, 110-220 VAC, Dual In 15 VDC Out
T8222 Power Supply Module, 24 VDC, Dual In 15 VDC Out
T8225 Trusted Power Supply Module 110-240V dc dual in, 24VDC out
T8230 Power Shelf, (incl. 4U Mounting K
T8231 Power Pack 24VDC (system)
T8232 Power Pack 28VDC (field)
T8233 Power Port
T8234 Power Controller
T8235 Power Shield
T8240 Power Shelf Type II
T8243 Power Port Type II
T8247 Power Shelf Support (pair)
T8270 24V dc Fan Assembly, Rack Mounting (Includes 1-off T8273)
T8271 Trusted Fan Tray 24V dc Roof Mounted
T8272 Trusted Vent & Baffle Unit for Fan Assembly
T8273 Grill for Fan Assembly, Rack Mounting
T8290 Output Power Distribution Module
T8292 Power Distribution Unit, MCB 24V dc
T8293 Power Distribution Module 15 Way Fuse
T8294 Power Distribution Unit, Regent Interface
T8300 Trusted Expander Chassis
T8310 Trusted Expander Processor
T8311 Trusted Expander Interface
T8312-4 Trusted Expander Interface Adaptor-4 Way
T8312-7 Trusted Expander Interface Adaptor-7 Way
T8314 Trusted Fibre TX RX Unit
T8380 Chassis Panel Rear Mounting Kit
T8402 Trusted Dual 24V dc Digital Input-60 channel
T8403 Trusted TMR 24V dc Digital Input-40 channel
T8423 Trusted TMR 35-120V dc Digital Input-40 channel
T8424 Trusted TMR 120V ac Digital Input-40 channel
T8431 Trusted TMR Analogue Input-40 channel
T8432 Trusted Dual Analogue Input-60 channel
T8433 Trusted TMR Isolated Analogue Input-20 channel
T8448 Trusted TMR Zone Interface-40 channel
T8449 Trusted TMR 24V dc Valve Monitor-20 Valves
T8451 Trusted TMR 24V dc Digital Output-40 channel
T8461 Trusted TMR 24/48V dc Digital Output-40 channel
T8471 Trusted TMR 120V dc Digital Output-32 channel
T8472 Trusted TMR 120V ac Digital Output-16 channel
T8480 Trusted TMR Analogue Output-40 channel
T8800 Trusted 40 channel 24V dc Digital Input FTA
T8801 Trusted 40 channel 24V dc Digital Input FTA, Non-incendive
T8802 Trusted 60 channel 24V dc Digital Input FTA
T8805 Trusted 60 channel 24V dc Digital Input FTA, Non-incendive
T8821 Trusted 40 channel 120V dc Digital Input FTA
T8824 Trusted 40 channel 120V ac Digital Input FTA
T8830 Trusted 40 channel Analogue Input FTA
T8831 Trusted 40 channel Analogue Input FTA, Non-incendive
T8832 Trusted 60 channel Analogue Input FTA
T8833 Trusted 20 channel Isolated AI/DI FTA, Loop Powered
T8835 Trusted 60 channel 24V dc Analogue Input FTA, Non-incendive
T8840 Trusted 8 channel Temperature VFTA
T8842 Trusted 40 channel Universal Versatile FTA
T8846 Trusted 9 channel Speed Input FTA
T8850 Trusted 40 channel Analogue or Digital Output FTA
T8870 Trusted 32 channel 120V dc Digital Output FTA
T8871 Trusted 16 channel 120V dc Digital Output FTA
T8891 Trusted 2 channel High Integrity Relay Output FTA
T8901 VFTA Fuse/Link Pack (10 off 50MA, 10 off 315MA & 10 off 2A)
T8902 FTA, 40 channel, Fuse Pack (10 off 50MA)
T8903 FTA, 60 channel, Fuse Pack (10 off 50MA)
TC-001-02 Chassis Power cable
TC-002-02 Power cable T8292 to T8293
TC-003-02 Power cable T8293 and input FTA
TC-004-02 Power cable, T8293 and Input VFTA
TC-006-02 Chassis Smartslot Link Cable
TC-011-02 Fan Power cable
TC-201-02 I/O Companion Slot, Internal, 40 channel Input to FTA, PVC
TC-203-02 I/O Companion Slot, External, 40 channel Input to FTA
TC-205-02 I/O Companion Slot, Internal, 40 channel Output to FTA
TC-207-02 I/O Companion Slot, External, 40 channel Output to FTA
TC-209-02 I/O Companion Slot, Internal, 40 channel Output to VFTA
TC-210-02 I/O Companion Slot, External, 40 channel Output to VFTA
TC-211-02 I/O Companion Slot, Internal, 40 channel Input to VFTA
TC-212-02 I/O Companion Slot, External, 40 channel Input to VFTA
TC-221-02 I/O Companion Slot, 16 channel, ac Output to FTA, Integral Power
TC-301-02 Local Expansion Cable
TC-302-02 Remote Expander Cable (Controller End)
TC-303-02 Remote Expander Cable (Expander End)
TC-304-01 Trusted Remote Expansion Cable EXP END
TC-305-01 Trusted Communication Cable FL
TC-306-02 Input SmartSlot Jumper Cable
TC-308-02 Output SmartSlot Jumper Cable
TC-311-02 Local Expansion Cable Assembly, 1 way
TC-312-02 Local Expansion Cable Assembly, 2 way
TC-313-02 Local Expansion Cable Assembly, 3 way
TC-314-02 Expander Extension Cable, Single Slice
TC-320-01 Trusted Interface Cable
TC-323-01 Power Shelf Interconnect
TC-501-02 I/O SmartSlot, Internal, 40 channel Input to FTA
TC-503-02 I/O SmartSlot, External, 40 channel Input to FTA
TC-504-02 I/O SmartSlot, External, 40 channel Input to Flying Lead/Freewire
TC-505-02 I/O SmartSlot, Internal, 40 channel Output to FTA
TC-507-02 I/O SmartSlot, External, 40 channel Output to FTA
TC-509-02 I/O SmartSlot, Internal, 40 channel Output to VFTA
TC-510-02 I/O SmartSlot, External, 40 channel Output to VFTA
TC-511-02 I/O SmartSlot, Internal, 40 channel Input to VFTA
TC-512-02 I/O SmartSlot, External, 40 channel Input to VFTA
TC-517-02 I/O SmartSlot, External, 40 channel Output to FTA, Integral Power
TC-601-02 I/O SmartSlot, Internal, 60 channel Input to FTA
TC-701-02 I/O Companion Slot, Internal, 60 channel Input to FTA
TC-801-02 I/O Companion Slot, Speed Monitor to FTA (internal)
PostPosted: Thu May 18, 2017 11:17 am
Hi Bruse, let me write you to have an advise from you if you can.
In my plant, we have an ICS triplex PLC and we want to add a new equipment
(contactor), so i prepared the program and i want to know if the
intelligent update can accept the new equipment or i must download the
program (a shutdown will occur in this case).
I want to thank you in advance
Best regards
I am sorry I have to paste your email content on this website because I don't know your email and I cannot email to you.
If you use Trusted, you add a contactor, do you modify too much program?
Don't worry, ICS Triplex Trusted support online download.
If you use AADvance and you modify the program, you have to shutdown the plant.
If you use AADvance and you don't modify the program, it is not need to shutdown the plant.
PostPosted: Sat Sep 15, 2018 1:44 pm
If you have the technical questions, please send to meverickcn@hotmail.com
Users browsing this forum: No registered users and 6 guests
