Hi i am using ABB 800xA 6.01 DCS system.
i want to made pdf of control logic.
How i will start?
pls help
ABB 800Xa 6.01 Logic PDF making
Re: ABB 800Xa 6.01 Logic PDF making
Just download and install PDFCreator.Search in google.Its free.
Open your software and open the program.
Click on the "File" tab and then print.
Once the printer options window opens "Select PDFCreator" and give the print command.You will get the logic on pdf format.
open control build M, and there is an option for you to print out all logic
hope it helps
hope it helps
