Hi All,
I have some problems with the TSX57 2634M PREMIUM
- I can not connect to the CPU through the mini DIN with the cable TSX CUSB485 + TSXCRJMD25
in SET ADDRESS Menu I choice :
ADDRESS : SYS
MEDIA : USB
-->Please can you tell me if I did the good selection.
Also this CPU have one port of Communication
- I can not connect to the CPU through the RJ45 port with the Ethernet cable " type straight"
ADDRESS : I convert the MAC address HEXADECIMAL TO DECIMAL : 00.80.F4.07.A1.34. I convert to Decimal 84.07.161.52
MEDIA : TCPIP
-----> the problem I can't connect because the address was changed by one person(he don't remember the IP)
--->My question regarding the Reset CPU as the factory setting.
Can you tell me how I can reset the CPU of TSX 57 2634M as the factory setting.
thanks
