[?]: unpassword XINJE PLC
другие контроллеры
ziconltai
Post by ziconltai » Sat Jun 22, 2013 1:49 pm
Hi ongtho 123!
It's look like Delta EH & Mitsubishi FX1N.
I think so try use the tools for them to test the password of Xinje XC3.
Good luck.
ongtho123
Re: [?]: unpassword XINJE PLC
Post by ongtho123 » Sun Jun 23, 2013 2:41 am
Thank you for your advice, i will try and let you know about result posting.php?mode=reply&f=3&t=19883&sid= ... 3d6b9949a7#
ongtho123
Post by ongtho123 » Sun Jun 23, 2013 3:23 am
Hi, i tried it with FX unlock password but not success :), Have you got any advice for this case?
hmohamed
Post by hmohamed » Fri Jun 28, 2013 11:08 pm
xinje PlC have a function (secret download) which u can not upload again
ongtho123
Post by ongtho123 » Sat Jun 29, 2013 2:18 pm
Thank you hmohamed, yes if xinje activate securedowload the program will show "Program code not exist".
I have question, in Xinje PLC when ladder too long (more than width row), how can i connect it like i did with FX1N or FX1S of Mitsubishi, I use GX Deverloper.
Regards
arm1612
Post by arm1612 » Fri Feb 14, 2014 3:25 am
Hi All,
I have Xinje XC3 PLC and it was downloaded by Secret Download. I have PLC program but i not sure if this one same with downloaded program. How can i compare it. Anybody have this experience before ?
milanjelikic
Post by milanjelikic » Mon Mar 30, 2020 8:08 pm
Hi all,
I am new here and was wondering for help about xc3 xinje plc.
1. if someone is greatfull to make short program in ladder of xc3 where i can use signal form encoder ( use for measurment of angle to 270 degress) that is will be nice. http://www.sah.co.rs/gts06-0p-ra1000b-2m-5222.html
2. how to connect encoder to xinje is that one of terminal "X" (input terminals) or it is A, B terminal near outputs ''Y''. ( Encoder has 5 wired (black - ; red +24v; green and yelow for signal; and 5th is ground)
3. The next problem i has it is comunication, when i try to download program to plc he sad modbus problem; i try online watch status inputs and outputs all working, i try to uplot program - work good .... what can be problem? i was use rs232 to usb converter, can that be problem?
TANKS IN ADVANCE all help u give me it is usefull!
TALEBABDELAZIZ
Post by TALEBABDELAZIZ » Mon Dec 07, 2020 9:56 am
How to delete a password for XINJE PLC
Toms
Post by Toms » Mon Dec 07, 2020 11:33 am
For some models, the password of Xinjie PLC can be obtained through NAND BIN data
mohammed ahmed
Post by mohammed ahmed » Tue Oct 05, 2021 1:40 pm
(gpost)
kawon53
Post by kawon53 » Sun May 08, 2022 7:36 pm
Regards
(wow)
mohammed ahmed
Post by mohammed ahmed » Sun Aug 21, 2022 7:08 pm
i have proplem when I make a connection with a plc xinje unit, I get a message "program code does not exist" Maher is the reason for this
mohammed ahmed
Post by mohammed ahmed » Sun Aug 21, 2022 7:13 pm
i have proplem when I make a connection with a plc xinje unit, I get a message "program code not exist" Maher is the reason for this
Tvhuy
Post by Tvhuy » Wed Nov 02, 2022 2:57 pm
Hi, does anybody have tool to crack plc xinje ?
I have plc xinje but it in lock, so can not access to copy program
Please help me.
Thank you so much
rakeshhc
Post by rakeshhc » Mon Dec 12, 2022 9:22 am
Hi, Did you get any solution? need help on cracking/removal software for Xinje XD5-48T6-E
amerasec2
Post by amerasec2 » Thu Feb 01, 2024 9:59 pm
