Roboguide V8.1056 Rev.C
другие контроллеры
Eert_NL
Post by Eert_NL » Thu Feb 07, 2013 6:29 pm
Hello all,
I've downloaded Roboguide V8.1056 Rev.C from the Fanuc FTP server.
The 30 day trial is over and I need to reactivate the software again before I go to their system training.
I've found a solution in another post and tried it but it didn't work.
The post I'm referring to : viewtopic.php?f=3&t=5518&p=42667&hilit=roboguide#p42667
Can anybody help me solve this problem ?
Beside that, if anybody is interested in the software, let me know.
Kind regards,
Erik
Shuravin
Re: Roboguide V8.1056 Rev.C
Post by Shuravin » Fri Mar 01, 2013 7:01 am
Доброе утро!
Eert_NL wrote:Hello all,
Erik
Сейчас покупаем робота Fanuc, но без программы roboguide.
Хотелось бы опробовать эту программу перед покупкой.
Пожалуйста, пришли ссылку для скачивания или сам файл.
С уважением из России.
P.S.: Если есть учебное пособие, то это будет просто прекрасно.
Eert_NL
Post by Eert_NL » Fri Mar 01, 2013 12:27 pm
Hello Shuravin,
I´ve send you a PM with a link in it.
Hope this helps.
Erik
sdf37
Post by sdf37 » Tue Mar 05, 2013 10:45 am
It's possible to reactivate Roboguide to new 30 days.
Use the software TRIAL RESET.
Eert_NL
Post by Eert_NL » Tue Mar 05, 2013 10:48 am
Hello sdf37,
Can you explain more ?
Maybe a link to that software ?
Have you tried it yourself ?
Did it work then ?
Kind regards
sdf37
Post by sdf37 » Tue Mar 05, 2013 1:56 pm
I have used this solution for Roboguid V7 but i have just intalled the V8, so i have not tested trial reset again.
Visit this site: http://fr.scribd.com/doc/16840394/Robog ... -Day-Trial
and download Trial reset at this address:
http://www.filecrop.com/81194268/index.html
Eert_NL
Post by Eert_NL » Thu Mar 28, 2013 11:18 am
Hello all,
After a long search for better options I finally found a way to fix my problem.
It's not the best solution but it works.
Install the software as usual.
Run it for like 30 day’s
If the software reaches it’s time then uninstall the software
1. Use the program “Trial-Reset”. I’ve tested version 4.0 Final.
2. Go to the menu called protection plus
3. Select “Scan generic” from the pull down menu.
4. From the same pull down menu select “Clear”
5. Reboot the computer
6. Reinstall RoboGuide
7. Reboot the computer
Done !
Hope this helps others as well.
If it does, please drop me a pb.
Regards, Erik
Eert_NL
Re: Roboguide V8 Ref. E
Post by Eert_NL » Mon May 13, 2013 11:48 am
Hello all,
I just got the latest version from Fanuc.
It has support for several new robots and its called RoboGuide V8 Ref. E
It also has new controller software v8.13 - R-30iB
P.m. me for more information.
Regards Erik
TornStar
Post by TornStar » Tue May 28, 2013 1:17 am
Would anyone have a download link to the trial version 8.10?
regards
moskito
Post by moskito » Thu Jan 23, 2014 11:29 pm
Eert_NL wrote:If the software reaches it’s time then uninstall the software
Regards, Erik
Does it work also for V8?
I paste another option pretty similar:
extracted from v6.40 / not checked
Show
This will reset your 30 day trial, after it ends:
Uninstall handlingpro/simpro/related components,
Delete these registry keys:
HKEY_CLASSES_ROOT\CLSID\{10459-d3d485b5-84d3-4f7b-acec-468ca308fdf0}
HKEY_CLASSES_ROOT\CLSID\{14742-df3ae7e1-0132-4a0b-a142-91977fc93e22}
HKEY_CLASSES_ROOT\CLSID\{801c08d1-cd91-486f-a44d-308cf5a69e3b}
HKEY_CLASSES_ROOT\CLSID\{8a05a2f8-6397-4b9a-8498-0d044d7655da}
Delete these files:
C:\WINDOWS\system32\ES2TPCPS.ocx
C:\WINDOWS\system32\INVDPB8V.ocx
Reinstall handlingpro/simpro, it should be good for another 30 days.
Eert_NL
Post by Eert_NL » Fri Jan 24, 2014 6:47 am
The solution as I wrote works with V8 Rev E as well.
I'm not sure about your solution, but off course you can try that too.
It still would be better if anyone could find a real solution for the trial key.
Regards
co2Cat
Post by co2Cat » Wed Feb 05, 2014 9:24 pm
Does anyone have the latest of the Roboguide software ?
alsiddhartha
Post by alsiddhartha » Thu May 01, 2014 7:37 pm
esta solución funciona. solo hay que aclarar bien los pasos.
1.- ejecutar el trial reset 4 (como administrador)
2.- buscar la opción PROTECTION PLUS
3.- ejecutar SCAN GENERIC
4.- ejecutar CLEAR
5.- desinstalar roboguide
6.- reiniciar pc
7.- instalar roboguide
8.- reiniciar pc
9.- funcionando 30 días mas
saludos
Eert_NL
Post by Eert_NL » Sun May 04, 2014 10:22 am
Eeeeh,
Why this (Spanish?) translation of my post?
regards
morecore
Post by morecore » Sun Apr 12, 2015 9:47 pm
Hi guys,
Bellow a medicine for Roboguide revE 8.1079.00.34.
Can be run under virtual machines too.
http://www.filedropper.com/patchroboguidereve810790034
Brune Wayce
Post by Brune Wayce » Sat Jul 04, 2015 3:06 pm
Done !
Regards, Erik
thankx a lot. It works!
But the Trial-reset.exe is detected as a virus from my system. I've run it, and then deleted (keeping just the .zip archive for future necessity...)
Is it normal? Have I download an infected version?
Thanks in advance!
Bye
tepisjrf
Post by tepisjrf » Mon Apr 11, 2016 4:20 am
Hi, morecore
can you please upload again the patch.
Thanks.
tepisjrf
Post by tepisjrf » Mon Apr 11, 2016 5:11 am
morecore wrote:Hi guys,
Hi, can you please reupload the file.
kavvis
Post by kavvis » Mon Oct 17, 2016 8:31 pm
Did anybody find "patch" for this? Please upload again
morecore
Post by morecore » Mon Nov 07, 2016 7:04 pm
Hi guys,
Sorry i've been very busy.
Install Roboguide then replace the original file with this one.
Link http://www.filedropper.com/rgcore
Give credits to the cracker not to me.
fotamecus
Post by fotamecus » Fri Nov 11, 2016 12:58 am
A sidenote:
The right version wicth work with the patch posted by morecore on previous post can be downloaded here
http://fabryka-robotow.pl/2014/04/fanuc ... 079-rev-e/
Enjoy!
fotamecus
Post by fotamecus » Fri Nov 18, 2016 6:13 pm
By the way, any patch to RoboGuide v8 RevK? ;)
RoboGuide v8 RevE has a known bug regarding ProfiBus configuration.
kavvis
Post by kavvis » Sun Nov 20, 2016 9:16 am
Anyone that have later version? M? And if any patch works for that version?
Should this post be on request?
velow
Post by velow » Tue Mar 26, 2019 6:37 pm
Please, could someone upload the patch again? Thanks in advance!!
