Hello the experts
Can you tell me, if it is possible to connect 3 PLC "through Ethernet" on the STB modules "IO deport- ref: STB NIP 22 12 "Modbus TCP IP". And the 3 PLC can give a command and status?
Thanks you for your technicals Supports.
regards.
STB Ethernet Commnication-Schneider IO deport
- Contact:
Re: STB Ethernet Commnication-Schneider IO deport
see doc
page 162:
page 162:
I have not tested, it is only in theorymax. no. of TCP connections supported = 33
Thanks a lot my Dear, I will try and when I do it I will come back to confirm, because sometimes the constructor of PLC between the reality and the theorie have a big difference.
once more thank you very much
