Problem with plc GE Fanuc VersaMax
другие контроллеры
antonio_dr
Post by antonio_dr » Tue Dec 11, 2012 8:26 am
A little bit history:
I had a problem with supply voltage - 220VAC come to 24VDC line
PLC, Power supplies (3 psc.), expansion transmitter, expansion receivers (2 pcs.) are burned.
Now I bought all those parts, but PLC don't work (only power lamp is lighting). I can't connect to it with serial, not Ethernet.
Where is the problem?
