I have a problem with a SanDisk 16MB PCMCIA Memory Card. After format on PC it is not seen by the robot.
If anyone have please provide me an image file for this.
With Best Regards
(Sorry for my English)
Request: Image file for 16MB PCMCIA memory card Motoman XRC
Re: Request: Image file for 16MB PCMCIA memory card Motoman
I had a similar problem and tired everything. The one that worked was using a different PCMCIA card reader and that seems to have solved the problem. Here is an attached file with images of the card. Hope this works for you. I found this somewhere on the web once.
http://www.2shared.com/file/Khyxlqqc/formatflash.html
